Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
« Volver a Todos los Cuentos
Replacement of trackpad on macbook air 11" late 2010
redc -
MacBook Air 11" Late 2010
MacBook Air 11" Late 2010 Trackpad Replacement
Moderate
Mi Problema
No possible click on at the left side of the trackpad.
Mi Solucion
With the exact repair procedure with photos from Ifixt, the replacement of trackpad was possible without any problems.
Mi Consejo
I bought a PRO TECH TOOLKIT, unfortunately the Pentalobe screwdriver used for the repair of the Macbook Air aren't Pro. The finish of the Pentalobe screwdriver isn't precise enough and the material used is too soft. That means for me, after the repair the Pentalobe screwdriver is useless. All the Pentalobe screws used to fix the bottom case are all fixed with blue screw glue. For the futur is would be useful to use better Pentalobe screwdriver, and even replace the Pentalobe screws from the bottom case with new screws since the screws are partially damaged due the bad quality of the Pentalobe screwdriver after the repair.
Imagen de MacBook Air 11" (Late 2010) Trackpad
$69.99
Imagen de Pro Tech Toolkit
Pro Tech Toolkit
$59.99
0 comentarios
Agregar Comentario
