Saltar al contenido principal
« Volver a todos los relatos
battery not holding up
William Knuckles -
iPhone 3GS
iPhone 3GS Battery Replacement
20 - 30 minutos
Moderate
Mi Problema
My wife's IPhone was shutting off at 97 percent. Now the phone is showing the lower numbers. Today, the phone got down to 14 percent. That is a REAL improvement.
Mi SoluciĆ³n
The repair went exactly as the instructions said. Had one little problem tho. The largest of the contacts didn't want to snap back together. Took 2 or three tries to get the contact to fasten. It finally snapped securely. I did NOT try to force it. I was REAlly gentle.
Mi Consejo
Do NOT try to work on an IPhone if you do not have any patience. You will pull your hair out, bang your head against the wall and then throw the phone. =) Make sure you follow the instructions and you will be fine.
Imagen de iPhone 3GS Battery
iPhone 3GS Battery
$14.99
Imagen de Spudger
Spudger
$3.99
Imagen de Phillips #00 Screwdriver
$5.49
Imagen de Metal Spudger
Metal Spudger
$2.99
Imagen de Heavy-Duty Spudger
Heavy-Duty Spudger
Imagen de SIM Card Eject Tool
SIM Card Eject Tool
$2.99
Imagen de Suction Handle
Suction Handle
$2.99
0 comentarios
Agregar Comentario
