Saltar al contenido principal
« Volver a Todos los Cuentos
adding a SSD to Mac Mini 2012
ryanvelting -
Mi Problema
I purchased a new Mac Mini 2012 (had a 2011 and wanted to get the USB 3.0 and better cpu) and I wanted to add a SSD as the drive that will run the OS. I had good luck installing this same kit in my 2011 Mac Mini.
Mi Solucion
The "repair" went quite well but I learned from doing this before that it works best to install the SSD as the top drive and only have 1 drive connected when you go to install the OS. At first I had both connected and OSX setup both drives as 1 (fusion setup)
Mi Consejo
if you are adding a 2nd drive and not wiping both drives make sure that you install the new drive into the kit and make your current drive the top one
Imagen Mac mini Dual Drive Kit
$26.99
0 Comentarios
Agregar Comentario
