Mi Problema
No problem
Mi Solucion
Hard drive installed with ease using the supplied kit - conventional drive (NOT SSD) fitted in the second bay. Only slight issue was fitting the Antenna cover back on (very tight - maybe just on mine) and watch the locating pegs for the original drive as they can be misaligned if you do not know they are there! Drive up and running - no problems so far
Mi Consejo
Non really apart from making sure the original drive is fully located (on its pegs) prior to installing the logic board
0 Comentarios
