Saltar al contenido principal
« Volver a todos los relatos
Nearly perfect home button replacement
platima -
iPhone 4
Imagen del relato
  • Imagen 1
  • Imagen 2
iPhone 4 Home Button Replacement
2 Hora
Difficult
Mi Problema
The previous home button was old, hard to press, and nearly impossible to double-tap. I also though a white button on a black iPhone would look pretty awesome.
Mi Solución
The repair wasn't hard, just took a while. Unfortunately when I put it back together though, the screen was on a slight angle and I have a thin tapered line at the top of the screen as a result (seen in the image).
Mi Consejo
Yeah, video record what you do so you can play it back if you're unsure about clips, screws, etc. Also be careful that you don't move the LCD panel attached to the front glass and end up with the result I did!
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 242
