« Volver a Todos los Cuentos
Need to fix/adjust the trackpad of a macbook unibody (white)
SuperDuperCruizer -
Mi Problema
Trackpad would not click.
Mi Solucion
Remove the battery & trackpad. Cleaned the trackpad and mounting surfaces with alcohol. Adjusted the torx screw, installed the trackpad, repeat until desired click returns.
Mi Consejo
You don't always need to replace your trackpad if the clicking mechanism is not functioning properly. Probably just an adjustment of the torx screw needed.
Imagen Tri-point Y1 Screwdriver
$12.99
0 Comentarios
