« Volver a Todos los Cuentos
iPhone 4 5-Point Pentalobe Screwdriver modification needed
dbuckel -
iPhone 4 Verizon
Imagen de cuento
iPhone 4 Verizon Rear Panel Replacement
5 minutos
Easy
Mi Problema
Purchased the screwdriver to repair a broken back cover on an iPhone 4.
Mi Solucion
Fixing the iPhone was very easy and quick. Unfortunately, the screwdriver had to be modified prior to use. The tip of the screwdriver was too long and came to too fine of a point to grip the screw.
Mi Consejo
Very, and I mean VERY, gently grind or file off a small amount of the excess tip. I'd suggest grinding a little and testing the fit and then grinding some more if needed. Be sure to keep the tip square to the grinder.
Imagen P2 Pentalobe Screwdriver iPhone
$8.99
Imagen iPhone 4 (CDMA/Verizon) Blank Rear Glass Panel
$14.99
0 Comentarios
