MacBook Pro 13" Mid 2010 Drive problems
jeff -
Mi Problema
The drive appeared to be failing with lots of beachballing. Took the drive out to connect it via an external carrier to another Mac and it worked perfectly. So I knew it was the controller or cable. Googled and for some reason this is a common problem. I'd love to know why?
Mi SoluciĆ³n
Easy. 5 minutes.
Mi Consejo
If you have drive failure symptoms on your MacBook Pro, check the cable first.
0 comentarios
