Saltar al contenido principal
« Volver a todos los relatos
replacement to the replacement battery did the trick
dgdeckert -
iPhone 1st Generation
iPhone 1st Generation Battery Replacement
55 minutos - 1 hora
Very difficult
Mi Problema
orig. battery was weak, didn't hold much charge
Mi SoluciĆ³n
The first battery from iFixit resulted in a phone that appeared bricked. Phone would start but not boot, not able to restore or leave recovery mode. DFU mode could be achieved but nothing else.
Mike picked up my comment on the "meta" site and suggested I send a note to support@ifixit.com, which I did. I was sent a new battery without asking for one, nor anything else. When I asked why this was I was told the battery or soldering job might have been bad ...
The second battery arrived, I removed the first replacement and reinstalled the phone's original battery --- it booted up perfectly. I removed that and installed the new, second battery from iFixit and all's well.
Mi Consejo
If you fear the worst, reinstall your old part and verify you can get back to the original condition that required a fix (if applicable, of course.)
And go slow with the back cover. I bent it where it meets the antenna cover and now doesn't close completely.
Imagen de Spudger
Spudger
$3.99
Imagen de Metal Spudger
Metal Spudger
$2.99
Imagen de Solder Wick Braid
Solder Wick Braid
0 comentarios
Agregar Comentario
