Mi Problema
Broken front panel after drop
Mi SoluciĆ³n
Came apart fine. I did cut the wifi antenna connection and the gasket did not survive the removal process. I consider this minor though because the panel has bee replace, parts have been ordered to fix my mistakes and most importantly, it works. Did a full backup once completed while plugged in.
Mi Consejo
With a shattered front panel, it does not lift clenly and come off in one piece which is why I think I cut the antenna connection. The depth of pushing in the spudger needs to be stressed. If you can see it under the clear part of the glass, it's too far.
0 comentarios
