Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
« Volver a Todos los Cuentos
Great, but with a couple of suggestions...
saab1 -
Mi Problema
I put an ugly dent in the narrow front edge of the top (keyboard) case of my nearly new (mid-2011) MacBook Air.
Mi Solucion
iFixit Install Guide is excellent, but a couple steps should be modified or added.
Mi Consejo
"Step 3 - Battery" Your guide suggests unplugging the battery, when in reality it NEEDS not only to be unplugged but also REMOVED.
"Step 37 - Track Pad" needs to be added. The track pad needs to be transferred from old top case to the new one, and no guidance is given. It's a bit tricky, with the connector located under the stuck-together ribbon cable, and a track pad set screw which needs to be properly adjusted. Also a warning about those extremely delicate track pad hinge screws.
"Mystery Clip" When I removed my logic board a tiny 1/8" long spring clip appeared from nowhere, and I have yet to figure out WHERE it belongs. The good news is that I'm typing this from my Air right now and it's working great, thank you!
Imagen de Spudger
Spudger
$3.99
0 comentarios
Agregar Comentario
