Saltar al contenido principal
« Volver a todos los relatos
MBP 3" Battery Replacement
Robert Girouard -
MacBook Pro 13" Retina Display Late 2013
MacBook Pro 13" Retina Display Late 2013 Battery Replacement
2 hora
Moderate
Mi Problema
Completely dead battery which turned out to be the cause of an extreme slowdown, apps bouncing in the Dock, constant beachballs, etc.
Mi Solución
Went very nicely. I followed the step-by-step instructions and read every comment appended to each step. I also watched multiple Youtube videos.
Mi Consejo
There really is no need to use the acetone/alcohol solvent until after you have removed the batteries and are removing the residue from the two-sided tape which held the batteries to the top case. Some YouTube videos suggested using dental floss, but that was insufficient to the task. I had some fishing line and that worked perfectly. The batteries, once I got the fishing line around them, came out surprisingly easy.
Imagen de MacBook Pro 13" Retina (Late 2013-Mid 2014) Battery
$99.99
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2
