Mi Problema
Device screen was cracked severally
Mi SoluciĆ³n
The repair was smooth process followed the guide step by step and everything went good.
Mi Consejo
Test the IPad once the new front panel is connected to the device before you remove the adhesive strips from the back of the new front panel. I usually test the touch, wifi, volume button, silent button, and camera. Also if the screen is badly cracked especially cracks that spread to the edge of the front panel I found that using an exacto blade made it easier to get under the adhesive at first so that I get my plastic opening tools under to finish cutting the adhesive away.
0 comentarios
