Saltar al contenido principal
« Volver a Todos los Cuentos
Not simple, but doable!
Pete H -
iPhone 5s
iPhone 5s LCD and Digitizer Replacement
3 horas
Moderate
Mi Problema
The screen was SHATTERED!
Mi Solucion
Only a few snags. Getting the iSight camera aligned when re-assembling can be a little challenging.
Mi Consejo
When you need heat - I use a hair-dryer on low fan, high heat for about 30 seconds and it worked superbly.
When you need to re-install the iSight Camera, get everything as close to where it belongs as you can. Get the bracket aligned, and then tighten the screws. Check the camera lens for alignment with a bright flashlight. If it's not aligned, loosen the screws and use a spudger to get the lens where you want it. re-tighten and check again. Do this BEFORE you put the entire phone back together!
Patience.
0 comentarios
Agregar Comentario
