Mi Problema
My airport card stopped working at random. Often when i moved the computer. Sometimes it worked to shut off the computer, open and close the lid a few times and start it again to get it working so i suspected a glitch somewhere and the cable was cheap so i thoughti might as well try changing it.
Mi SoluciĆ³n
Very easy install, just unscrew the bottom cover and pop out the old cable and in with the new one.
Mi Consejo
If your airport card is failing this might be the cause. The fix is cheap enough to do even if it might not solve the problem.
0 comentarios
