Mi Problema
Power button was not working, and the battery was failing.
Mi SoluciĆ³n
It was ok. The battery was rather hard to peel out, but after that, the power button procedure was ok.
Mi Consejo
The guide says to un-hinge the power button before the cable is detached from the back case. I found that I had to take the volume buttons and ringer select switch off and peel up the cable before I was able to un-hinge the power button. Once the cable was free, I was able to maneuver the power button off the hinge.
0 comentarios
