iFixit Opening Tool
  • Cerrar 360°
  • 360°
360
iFixit Opening Tool
Plastic tools designed to get you in the tightest cracks, without damaging your treasured devices.
$1.99
$1.99
Te enviaremos un mensaje cuando el producto esté de regreso en stock.
Nueva batería = iphone mas rápido
Fix kits a partir de $16.99
Detalles del Producto
Características
Características
The primary tool for opening everything
  • Custom-designed handle provides no-slip opening power with plenty of grip.
  • Tough-yet-soft material prys open the tightest cracks, but won't scratch or mar your workpiece.
  • Two tips provide alternate opening options: Wedge for breaching, and Hook for lifting and levering.
  • Convenient pack of 5 tools, for 10 total prying tips!
Video del Producto
Cuentos de Reparación
Avatar de usuario
Mi Problema
My iPhone 6 Plus display recently started flickering and, at times, became unresponsive unless I literally forcibly twisted the phone in order to get it to respond. This issue was extremely annoying and frustrating, especially when trying to answer a call. So, I had three choices. Buy a new iPhon . . .
Avatar de usuario
Mi Problema
The top corner of my screen cracked a whole hour after I took my case off, so I decided to get in touch with my iFixit friends to get it repaired. While I was doing that, I decided to replace the battery as well.
Mi Solucion
It was a piece of cake! The Repair Kit had everything I needed, and was labeled perfectl . . .
Avatar de usuario
Mi Problema
My phone would need to be charged at least 2-3 times a day with moderate normal use. There were times where it would shut off completely with 50-80% battery life showing. Very hard to rely on a phone under the conditions so I purchased the battery fix kit from ifixit and could not be happy with how . . .
Avatar de usuario
Mi Problema
Found an old iPod, thought it was a gonner. After a quick Google I found this website couldn't believe they had everything I needed and instruction! Anyway super easy super fast delivery and now I'm jamming like the old days.
Mi Solucion
Went great really easy.
Mi Consejo
Raise your dead....devices.
Avatar de usuario
Mi Problema
The battery had bulged and forced the display to gap in a couple places. This actually made it easier to open the iPad.
Mi Solucion
Very straight forward however, I used the WIFI repair guide and my iPad has Cell built in too. There are two more mini coaxial connectors and a little more work than the guide sho . . .
Avatar de usuario
Mi Problema
Our iPad was having difficulty initiating and completing a charge. After charging to 100% and removing from charger, power quickly dropped to nothing in a few minutes. I tried removing apps, resetting the iPad, and completing a full charge cycle. Nothing seemed to help and the iPad became unusabl . . .
Avatar de usuario
Mi Problema
Old battery no longer held a charge
Mi Solucion
99% of the time spent fighting the glue on the old battery. An iFixit Opening Tool and a old credit card worked for removing the case and old battery. the Spudger helped with removing ribbon cables.
Mi Consejo
1) The correct screw size for my nexus 5 was PH000
2) For the new b . . .
Avatar de usuario
Mi Problema
The micro USB port was no longer accepting electricity to charge the battery. The port itself can not be removed from the motherboard without breaking solder.
Mi Solucion
Replacing the motherboard was the easiest thing I've ever done on an electronic device. Once the case was opened, all that was required was . . .
Avatar de usuario
Mi Problema
My son's Tab 4 wasn't charging, so I tried repairing with the cheaper possibility first (the battery).
Mi Solucion
Really smooth, simple, and quick.
Mi Consejo
For those of you who are "champions of breaking those little plastic tabs" like I am, I highly recommend the opening tool. So simple, yet it got me in the tablet in . . .
Avatar de usuario
Mi Problema
After trying half a dozen shapes of screwdrivers for over an hour without success, the fix-it tool popped off the case in a few minute
Mi Solucion
Did as advertised.
Mi Consejo
No. Just watch the video.
Mostrar más
