Universal Bit Kit
  • Universal Bit Kit / New
  • 360°
360
Universal Bit Kit
The complete bit set for any repair enthusiast.
$99.99
$99.99
Te enviaremos un mensaje cuando el producto esté de regreso en stock.
Detalles del Producto
Descripción
Descripción
  • 128 steel bits in both 4 mm and 1/4" sizes for precision work and large torque application.
  • CNC machined aluminum driver handles for both 4 mm and 1/4" bits provide plenty of grip while driving screws.
  • Elegant oak case keeps all components secure and conveniently displayed.
Bit List
  • Phillips 000, 00, 0, 1, 2, 3
  • Flathead 1, 1.3, 1.5, 2, 2.5, 3, 3.5, 4, 5, 6, 7, 8 mm
  • Torx T2, T3, T4, T5
  • Torx Security TR6, TR7, TR8, TR9, TR10, TR15, TR20, TR25, TR27, TR30, TR35, TR40
  • Hex 0.7, 0.9, 1.3, 1.5 mm
  • Hex Security 2, 2.5. 3, 3.5, 4, 5, 6, 7, 8 mm
  • Hex SAE 1/16
  • Hex Security SAE 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4
  • Nut Driver 2.5, 3, 3.5, 4, 4.5, 5, 5.5, 6, 7, 8, 9, 10, 11, 12 mm
  • Nut Driver SAE 1/4, 3/8
  • Square 0, 1, 2, 3
  • Pozidriv Pz0, Pz1, Pz2, Pz3
  • JIS J000, J00, J0, J1
  • Torq-set 6, 8, 10
  • Tri-wing 0, 1, 2, 3, 4
  • Tri-point Y000, Y00, Y0, Y1
  • Pentalobe P2, P5, P6
  • Clutch 1, 2, 3
  • Gamebit 3.8, 4.5 mm
  • Spanner 4, 6, 8, 10, 12
  • Triangle 2, 3 mm
  • Spline M5, M6, M8
  • Oval Bit
  • SIM Eject Tool
  • Magnetic Pickup Tool
  • Schrader Valve
  • Hook and Loop Fastener
  • 1/4" to 4 mm drive adapter
  • 1/4" driver to 1/4" socket adapter
  • 1/4" driver to 3/8" socket adapter
  • 1/4" socket to 1/4" driver
Video del Producto
Cuentos de Reparación
Avatar de usuario
Benjamin Rodriguez's Story Photo #1013595
Mi Problema
Battery is damaged
Mi Solucion
Quite easy
Mi Consejo
If you put more guides that are good to learn
Avatar de usuario
Mi Problema
User spilled coffee onto their keyboard, computer shut off.
Mi Solucion
Better than anticipated. First in-house repair of a logic board.
Mi Consejo
Magnetic board to organize screws and the 128-bit kit to have everything.
Avatar de usuario
Mi Problema
My Apple watch screen suddenly came off of the frame as the adhesive material must have some how been damaged. So the screen was hanging from the frame by a few tiny connections!!!!
Mi Solucion
I took it to Apple to get it fixed and they quoted me 3 weeks time plus 275$+13% tax to fix it as I was out of warranty . . .
Avatar de usuario
Mi Problema
The Problem started when my dog knock over water on my wife mac.
Mi Solucion
The repair went well, though i should of bought the ifix it business tool kit because some of those cable are really small.
Mi Consejo
I never done a repair that did not had any remaining screws. Just follow the step that Ifix it provides and you w . . .
Avatar de usuario
Mi Problema
It had been dropped
Mi Solucion
My blind grandmother could have fixed it....
Mi Consejo
If you need help go to ifixit
Avatar de usuario
Mi Problema
The battery of my Macbook Pro 15 - 2011 died on me.
Mi Solucion
It took about 7 min and was great.
Mi Consejo
Just read the instruction before you order.
Avatar de usuario
Mi Problema
The current 500GB drive had run out of space, so we upgraded to 4T.
Mi Solucion
Everything went well, however a word of caution. The video cable mount is very tiny and you need small hands to reseat it.
Mi Consejo
You don't need to remove the LCD screen, you can reach the screws that hold the drive in place by simply liftin . . .
Avatar de usuario
Mi Problema
Problem - Daughter's Boyfriend Electrical Engineer - Idea for gift!
Mi Solucion
He loved it! Several times while he was at our house, I found him simple pulling out each bit and playing with the two drivers. My daughter said he had to hide them from his Dad. Maybe Dad will get a set of his own.
Mi Consejo
Oh yes, advice... . . .
Mostrar más
