P5 Pentalobe Screwdriver Retina MacBook Pro and Air
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air / iFixit - Made in Germany / New
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air / Moody - Made in USA / New
$8.99
$8.99
Te enviaremos un mensaje cuando el producto esté de regreso en stock.
Detalles del Producto
Descripción
Descripción
Use this precision P5 pentalobe screwdriver to open Retina MacBook and MacBook Air laptops. The P5 driver is compatible with the 5-point star shaped pentalobe 5IPR security fasteners used on the bottom of some Apple laptops.
The iFixit P5 pentalobe screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision P5 pentalobe screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Cuentos de Reparación
Avatar de usuario
Mi Problema
battery was dying and had "service battery" alert in notifications panel
Mi Solucion
Went well except that the cord for the new battery was incrementally too short. It was able to plug in barely and on a slight angle, Hopefully this will be okay long-term; my concern is having to periodically open the assembly a . . .
Avatar de usuario
Mi Problema
Needed more RAM memory to upgrade to High Sierra OS.
Mi Solucion
Great.
Mi Consejo
Make sure you hav the correct RAM memory because there are various types.
Avatar de usuario
Mi Problema
My MBP trackpad was broken. Needed the pentalobe screwdriver to open my laptop to replace the trackpad.
Mi Solucion
Huge pain in the ass. On my model of macbook pro, you have to remove the batteries which are glued-in to get access to the track pad. I saw a guy on youtube use a metal scraper to do it, so I did t . . .
Avatar de usuario
Mi Problema
Battery for Mac Air was dead. Ordered P5 Pentalobe Screwdriver and a battery on Ebay. Followed the directions on IFIXIT, which were excellent.
Mi Solucion
Everything went without a hitch. Thank you!
Mi Consejo
Follow directions. Carefully unplug and reconnect battery.
Avatar de usuario
Mi Problema
After five years the battery had cycled hundreds of times and was showing a need for service...
Mi Solucion
The swap was quick and easy... less than 20 minutes... great repair guide and product.
Mi Consejo
ifixit.com should always be the first place you try.... great advice and solid products...
Avatar de usuario
Mi Problema
Original Logic Board had failed
Mi Solucion
Repair went without a hitch.
Mi Consejo
Follow the instructions!
Avatar de usuario
Mi Problema
Trackpad kept drawing squares
Mi Solucion
Good.
Mi Consejo
I used a T6 screwdriver instead of a T5 on step 10. Don't removed a metal plug that appears to be taped to the bottom underside of the trackpad.
Avatar de usuario
Mi Problema
My laptop stopped being able to hold a charge. Left more than a minute unplugged the system would shutdown.
Mi Solucion
Easier than I expected. Strangely only 4 screws were holding the case, either the others fell out or were left out by apple repair in the past.
Now the laptop can remain operational while un . . .
Avatar de usuario
Mi Problema
My fan was making a weird noise. I didn't know if the fan motor was dying, or if some debris was the culprit. In either case, I needed to open up and have a look. Unfortunately, I didn't have the special pentalobe screwdrivers to open up my MacBook.
Mi Solucion
My biggest problem was that I didn't even know whic . . .
Avatar de usuario
Mi Problema
My sister accidentally dropped her Macbook Pro Retina after owning for more than 4 years. The warranty had expired a long time ago and the people at the Mac store gave an estimate of at least $700. When my family told me about this, I told them that was ridiculous and to order a new display from ifi . . .
Mostrar más
