Magnetic Project Mat
$19.99
$19.99
Te enviaremos un mensaje cuando el producto esté de regreso en stock.
Nueva batería = iPhone más rápido
Fix Kits a partir de $16.99
Detalles del Producto
Características
Características
Repair can be tough. This mat makes it easier.
  • Simply organizes all your parts while you work on a device.
  • Dry erase surface lets you keep notes and stops mistakes.
  • Reduces reassembly time by up to 40% while preventing errors.
Designed by fixers, for fixers, the 8”x10” Magnetic Project Mat solves this repair problem. Spacious and secure, the mat will catch and hold screws as you pull them out of a device.
Great for cell phone repairs, and you can stop worrying about screw tracking and focus on the cell phone all the screws will be right where you left them. For laptops with hundreds of screws, use the whole mat as a screw guide and keep careful notes to not get lost.
The included pen is uniquely suited for the Project Mat. It’s made by Staedtler, the German pen company that makes top-of-the-line pens and pencils for artists and architects. Their Lumocolor Correctable pen doesn’t smear or wipe away like most dry erase markers, so if you brush your hand across the mat while performing a repair, the ink doesn’t scratch or smear. However, the eraser tip or a dry cloth wipes the ink away clean.
Pen wearing out? We have replacement pens.
Video del Producto
Cuentos de Reparación
Avatar de usuario
Jacob Bramante's Story Photo #1291959
Mi Problema
My battery life was short and the laptop would shut down at 50% or higher if I had a portable drive connected.
Mi Solucion
Thought about trying to cheat the repair by not removing the logic board et al, but then just settled in for the long slog as I've been working on computers for years (built my first one in . . .
Avatar de usuario
Mi Problema
got it to be prepared for a problem.
Mi Solucion
have the tools to do the work.
Mi Consejo
None yet.
Avatar de usuario
Mi Problema
Battery was not holding a charge for any longer than a day.
Mi Solucion
Great instructions, good pictures, bad experience. It all began like the instructions indicated by removing the two external screws, placing suction cup on screen and attempting to separate the screen from the body. After numerous attempts . . .
Avatar de usuario
Mi Problema
My battery was ruining my phone. It destroyed 2 cables and was rendering my phone useless.
Mi Solucion
It was straightforward and fairly easy. If you can shade tree mechanic then you can fix a phone no problem.
Mi Consejo
Pay special attention to the screw lengths and where they come from and go back to. There are notes f . . .
Avatar de usuario
Mi Problema
The price of adding more SSD storage and memory via Apple Store is extremely costly.
Mi Solucion
It is definitely a moderate to difficult task in performing this upgrade but it was well worth it! Interested parties should also read advise about how to deal with slow boot-ups if they also upgrade the SSD at the s . . .
Avatar de usuario
Mi Problema
Noticed more cellular data use and gps data unreliable on my daughters phone
Mi Solucion
Just follow the directions, it was easy
Mi Consejo
If you have a low wifi signal and the gps location is not very accurate, this is the fix
Avatar de usuario
Mi Problema
Son proyect
Mi Solucion
Son proyect
Mi Consejo
Son proyect
Avatar de usuario
Mi Problema
My daughter's phone battery would go from 50-60% to shutdown in minutes, especially outdoors in cold weather.
Mi Solucion
In addition to the repair kit, I bought an iSclack, an iOpener, and the magnetic project mat. The iSclack is worth its weight in gold. The magnetic project mat is worth ten times that. I d . . .
Avatar de usuario
Mi Problema
The battery would only hold a charge for a few hours. I thought, “Rats! I don’t like replacing a phone when it was otherwise perfectly meeting my needs.” Then I heard about Ifixit and the possibility of fixing it myself.
Mi Solucion
The guides were so detailed it made the process easy. Equally important w . . .
Avatar de usuario
Mi Problema
I was hitting thermal limits on my graphics card during this excessive heat wave in california. Decided to do a budget friendly mod on it. Replaced the stock gpu fans with case fans. Problem was i couldnt remove the stock fans because i didnt have the tips needed for it.
Mi Solucion
Great! I was able to remove t . . .
Mostrar más
