Essential Electronics Toolkit
Limit 5 per customer.
$19.99
$19.99
Te enviaremos un mensaje cuando el producto esté de regreso en stock.
Nueva batería = iPhone más rápido
Fix Kits a partir de $16.99
Detalles del Producto
Características
Características
Our most economical do-everything toolkit. The Essential Electronics Toolkit is what you need for the most essential electronics repairs—like screen and battery swaps—and everything you need for most household DIY fixes.
Get started in electronics repair with all the bits and precision tools to handle your most urgent screen breaks and battery swaps. Or simply upgrade your home DIY toolkit with what you need to service door knobs, home appliances, eyeglasses, and more.
Kit Includes
Cuentos de Reparación
Avatar de usuario
Sean Lichtenstein's Story Photo #1330869
Mi Problema
Cracked/Smashed IPhone 6S screen
Mi Solucion
It went well! A little more difficult than I expeted but the guides were a fundamental help with this repair- I would not have been able to complete it without them!
It was a bit tricky getting the Home button in place as well as the earpiece speaker and camera- but . . .
Avatar de usuario
Andrew Kubicka's Story Photo #1183403
Mi Problema
I was completely unable to use any of the functions of Wifi, bluetooth or location servies. I would not pick up any wifi networks, any bluetooth connections would connect and disconnect a few times before never connecting again, and location services could barely pick up my location (on occation up . . .
Avatar de usuario
Mi Problema
It had the 3 beep of death. I purchased 2, 8s of ram for a total of 16, however. It would not allow this. So ended up with 10gb. Initially I thought I had a bad top ram slot. But the 2gb took. But had to put them in one at a time to test them. I truly would not wanted to replace the logic board. S . . .
Avatar de usuario
Mi Problema
I replaced the battery, fan, and right speaker/subwoofer
Mi Solucion
Took my time and reviewed videos over and over. Everything went smoothly.
Mi Consejo
for images, I would show the before and after shot of how to remove certain connections. I didn't know how to remove a certain piece from your website, but found out fro . . .
Avatar de usuario
Mi Problema
My MacBook Pro Early Rubber Feet has left and I was replace it with MBP Rubber Feet that i was buy on iFixit Store. I buy Essential Electronics Toolkits to do this.
Mi Solucion
First, i replace botoom case my MacBook Pro and then replace 4 rubber feet.
Just do it.
Mi Consejo
You don't need adhesive 'cause iFixit MBP Rubber . . .
Avatar de usuario
Mi Problema
Still using the original battery in 2018 so decided it was time.
Mi Solucion
Replacement went smoothly -- except for the enclosed tools. I recommend purchasing the toolkit to avoid stripping the screws.
Mi Consejo
The four screwdrivers are really just toys; please either spring for a better set of just do away with them.
Avatar de usuario
Mi Problema
Hard drive died. My first delve into computer guts. Drive seemed fine, head not stuck, but made clicking noise. Decided I wouldn't be able to recover. Maybe circuit board... Bought Evo 256Gig SSD and while looking around the delightful ifixit site, discovered the discussions about upgrading the . . .
Avatar de usuario
Mi Problema
Problems: 1) GPS was not identifying my location very well. gave a rather large cone of uncertainty and turn-by-turn directions was not usable. 2) wifi connectivity was suspect. my device had to be very close to a router to connect. 3) bluetooth connectivity was also bad. my device had to be very cl . . .
Avatar de usuario
Mi Problema
Regardless of charger or cable, charge rate was only 300 mA. New battery did not help.
Mi Solucion
Even with the iFixit tools (very nice), the case got a little dinged. The glue holding the board was more tenacious than expected.
Mi Consejo
Take your time. Use little force. Don't bend boards or cables more than necessary. B . . .
Avatar de usuario
Mi Problema
I've previously had Apple repair the cable while it was under warranty and that cable subsequently went out about a year after that. I was able to scavenge a HD cable from another MacBook Pro (mid 2011) and while not ideal, it worked well enough. Now I had the money and time to double down on the ca . . .
Mostrar más
