Saltar al contenido principal
Modelo A1224 / mediados de 2007 y principios de 2008/2, 2,4, o 2,66 GHz Procesador Core 2 Duo
Preguntas 548 Ver todo
Why am I getting an Apple Hardware Error 4MOT/1/40000003:HDD-1364
Why am I getting an Apple Hardware Error 4MOT/1/40000003:HDD-1364 and what might be possible solutions?
Es esta una buena pregunta?
Puntuación 1
1 comentario
Did this ended up fixing the issues?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
If it starts with 4MOT it's a motor (fan) error
If it ends in HDD it relates to the HDD fan, The number at the end is the actual rpm for the fan.
This error is generated if the actual fan speed is outside the +/- 10% allowance for the target speed. So you likely have a failing fan nearest the HDD
I'd be sure to backup any PITA data on the HDD, as it may be/have been acting up (overheating) which is caus(ed)ing the fan to fail.
''If this answer was helpful please remember to return an mark it Accepted.
Fue útil esta respuesta?
Puntuación 4
Añadir tu respuesta
Marcus estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,735
