Saltar al contenido principal
Modelo A1288 / 8, 16 o 32 GB de capacidad
Preguntas 451 Ver todo
it turned off, and it only works on power from the wall
I got it to work off battery for a while by hitting the back rather hard, but now that wont get it working, my guess is that something is loose inside. it will work from my wall charger adapter but not my computer. the instant i unplug it it cuts off.
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
4 Respuestas
Solución Elegida
Here's how to replace the battery: Sustitución de la Batería del iPod Touch 2ª Generation
Here's the replacement battery: iPod touch (2nd Gen) Battery
Fue útil esta respuesta?
Puntuación 1
1 comentario:
I have dropped it once but it was in a case, so something might have come loose
- de
Well I beat the hell out of it and it works again, but obviously, continuing to do this can't be very good. I have to hit the back to make it work
Puntuación 1
You're just gonna have to open it up and inspect the connections. You might want to order a replacement battery so when you have it open you can replace the old one if needed. My guess would be a faulty battery as I doubt the connections could get loose inside.
Puntuación 0
The connections to and from the battery are soldered. Coming loose is a very slim possibility.
Puntuación 0
1 comentario:
well they ARE made in china. $*$^ happens to stuff made in china. Like the Toyota brakes. And the lead and the melamine and the exploding tires and the flaming laptop batteries and the radioactive childrens jewelry.
- de
Añadir tu respuesta
trevor estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 862
