Saltar al contenido principal
El primer modelo de iPhone, modelo A1203 con 4, 8 o 16 GB de capacidad y una parte posterior de aluminio. La reparación requiere una cantidad significativa de destreza, y puede requerir un poco de soldadura.
Preguntas 224 Ver todo
Screen is "locked up"
I have the original battery, it still takes a charge and phone was working properly. dropped. no obvious external damage. pushing the round recessed button lower center, or the black on button adjacent to the sim card produces the same result. black screen appears for < than 1 second.
Screen has an image of the planet earth upon which is superimposed a boxed msg "waiting for activation". slide to unlock does not respond, and screen goes black. sim card swapped for a known working card, with no change in symptoms.
What do you think the issue is? What parts do I need?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Can you connect to iTunes? If so, backup and restore the device.
If this doesn't fix the issue, try bringing the phone to a store of your phone service provider to see if they'll take care of it (DON'T MENTION THAT YOU DROPPED IT).
Good luck!
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
sam estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,053
