alan peake, not a real terrible job:-) Few things you have to do :"
Remove the Side Ornament (L) / (R) :
Remove
SD Card
Battery
4 Screws (A)
2 Locking tabs
Side Ornament (L)
Side Ornament (R)
To remove the Rear Case Unit :
Remove
2 Screws (B)
Rear Case Unit
To remove the Front Case Unit:
1 Screw (C)
Front Case Unit
To remove the LCD Unit
REmove
FP9006 (Flex)
FP9007 (Flex)
FP9008 (Flex)
2 Locking tabs
LCD Unit
Now here is where it can get interesting, this camera apparently has a separate backlight, so be careful with the flex cables.
I attached a few images that should help you. The parts image 24-1 shows the touch panel. The part number is VYK5C81 and it is available for around $70 at places like this.
Hope this helps, good luck.
