Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1238 / disco duro de 80, 120 o 160 GB / frontal de metal negro o plateado
Songs won't initiate on my iPod Classic 80GB
The songs appear but won't start to play. It is not a soung issue.
Es esta una buena pregunta?
Puntuación 3
5 comentarios
Thanks Mayer...all fixed...and I was ready to turf it!
- de
Welcome ;-)
- de
Thanks this worked straight off
Cheers !
- de
I tried factory reset it says corrupted ipod wont turn on now what do I do?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
In many cases restarting Apple iPods will fix this issue. Do this by toggling the Hold switch on and off. Then press and hold the Menu and Center (Select) buttons simultaneously until the screen flickers and the Apple logo appears. Assuming you have tried that and now need more help you will need to go to the computer. As a general fix all for an iPod you should try a complete Factory restore. This will wipe all the music off of the iPod and then take it back to its original conditions. You can then copy all your songs from iTunes back to the iPod.
Fue útil esta respuesta?
Puntuación 12
17 comentarios:
This helped me with my iPod classic, in April 2020!
Thanks!
- de
The iPod is old and it worked last week but not now. It powered up fine and I could toggle through menus but it would not start playing a song. I did a quick Google search of the issue and found this answer first. It worked perfectly! Back in business! THANKS!!!
- de
Jeff, please give your thanks by up voting the answer ;-)
- de
I wasn't sure what to do once the Apple logo showed up, but then the normal screen showed up. Thanks!
- de
12/11/2020 Thank you! My IPod Classic was not playing consecutive songs, Googled the same and found the answer. Thanks again!
- de
Mostrar 12 comentarios más
This worked for me! Thank you!
Puntuación 0
Añadir tu respuesta
kate faraone estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 23
Ultimos 30 días: 56
Todo El Tiempo: 12,524
