Can I fix flexgate by replacing a cable, not the whole display?
“I have the "flexgate" problem in my MacBook Air 13" Retina Early 2020 (Intel) - mode A2179. I would like to try to fix it by replacing the cable rather than the entire display.
Is this possible? Where can I find the cable? I didn't see it for sale on ifixit.”
Es esta una buena pregunta?
3 comentarios
Why do you think the issue is within the flex cables?
What are your symptoms. There maybe another issue than needing to replace the flex cable.
- de DanJ Compartir
"flexgate" refers to the problem, not the cause. It's a phenomena in some Macbooks, including mine, where the screen goes black when the Macbook is fully opened but is totally visible though difficult to use when only opened about 45 degrees.
- de Josh Kuperman Compartir
@joshkuperman - Then it's the backlight cable that's damaged, if you can see faintly the image on the screen. This series had more of a grit issue exposing the traces than a cracked conductor due to bending.
You might only have a scuffed up cable which only needs cleaning and an insulator placed over the damaged area.
- de DanJ Compartir
