Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Información de reparación y desmontaje para el smartphone Android Samsung Galaxy S21 5G, incluido el modelo SM-G991U.
What size triangular screw bit do I need for my S21 G5?
I bought a new screen assembly for my phone which is great as I do not have to reinstall the adhesive on the screen. However when moving the parts over I noticed there was a ribbon that was not on the new part and not really mentioned in any of the guides. It is secured in place with a bunch of tri point screws, which did not come with my kit. I've seen the cable referenced in a few guides as the orange 5G cable, but none of them approach it. The ribbon looks like it says 0_NA ESLD. I am trying to figure out if I need Y0, Y1, etc or something else. Also if there are any tips since I can not find a single guide that mentions removing this part.
You can see the screws right above the vibrator in the images below:
Imagen
Imagen
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
The tri-wing screws as you mentioned don't use a triangle (TA) driver, they use a tri-wing driver. I think the size is Y000 or Y00 (1.5 or 0.6mm) if you try to use an actual triangle driver they are likely to strip. I guess calling it a Y driver (which it basically is) would lead to too many "but Y?" comments 🤔
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Jack estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 71
