Saltar al contenido principal
Envío gratis en pedidos nacionales de $75+
Información sobre reparación, desmontaje y resolución de problemas del smartphone Android Infinix Smart 8, incluyendo los nombres de modelo Infinix X6525 e Infinix X6525D.
My phone is not turning on even if I charge it
My phone is not working
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 8
2 comentarios
The phone is not on but the engine is hot
- de Compartir
I don't know why my phone is not working
- de Compartir
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Try these steps in order — most "won't turn on" cases are fixable without opening the phone:
1. Force a hard reset
Press and hold Power + Volume Down for 15–20 seconds, even if the screen looks completely dead. This forces a reboot on most Infinix/Android devices and fixes a surprising number of "frozen" phones.
2. Rule out a charging problem, not a power-on problem
  • Try a different cable and a different wall adapter (charging cables fail more often than phones).
  • Plug in and wait 15–20 minutes before pressing power — if the battery drained to 0%, it can take a while before the charging LED or screen responds.
  • Watch for any sign of life: LED blink, brief vibration, or the screen flashing for a split second. That tells you the phone is getting power but not booting fully.
3. Check the charging port
Look inside the USB-C port with a flashlight for lint, dust, or a bent center pin. Gently clean it with a wooden toothpick or a can of compressed air — never a metal object.
4. Try a different power source
Plug into a laptop USB port or a different wall charger. If the phone shows a charging animation there but not with your usual charger, your original charger/cable is the culprit.
5. Look for the "dead battery" charging icon
Some Infinix models show nothing for the first few minutes when the battery is fully drained. Leave it on the charger, screen off, for a full 30 minutes untouched, then try powering on.
If none of that works:
This usually points to either a battery that has failed completely (won't hold or accept charge) or a charging port/board issue that needs a diagnostic. At that point it's worth:
  • Posting back here with any details (LED behavior, vibration, warmth near the port, when the issue started — did it die suddenly or gradually?)
  • Checking iFixit's Infinix Smart 8 guide page for a battery or charging port replacement guide, since those are the two most common failure points on this model
  • If it's still under warranty, an Infinix service center may be faster/cheaper than DIY at this stage
Let us know what happens with the hard reset and the different charger — that'll narrow down whether it's a battery, a port, or something else.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
@whitescreen IFixit doesn't have a useful guide to replace this phone, yet. And please make sure to check the AI's answer before posting it here. Sure, it could actually be helpful, but you always have to double check the prompt in order to actually make it helpful. An AI prompt for this always has to have a real human check to see if it is correct.
- de Compartir
Hello,
You would need to replace your battery if this is happening. Go online, search up the correct battery for your use, and follow a useful guide created by an actual human, not AI, to replace your battery.
Good luck,
T
Puntuación 1
Añadir tu respuesta
John Jerry estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 36
Ultimos 30 días: 211
Todo El Tiempo: 895
