Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
El Malibu fue rediseñado para la séptima generación en 2008. Esta generación del Malibu se presentó en muchos niveles de acabado: el Base (solo 2008) (1SB), el LS 1LS (o 1FL para modelos de flota de 2011 y 2012), el LT 1LT (o 2FL para modelos de flota de 2011 y 2012), el Hybrid (solo 2008 y 2009), y el LTZ 1LZ. Solo el paquete de acabado superior LTZ estaba equipado con lentes de luz de freno transparentes con luces LED rojas, mientras que el resto de los paquetes de acabado conservaron las lentes rojas con bombillas de luz de freno convencionales.
2008 Malibu NO CRANK NO START NO SECURITY LIGHT
I lost the ignition key for my 2008 Chevy Malibu last winter. I went to the dealership and got a new key and followed the steps at home to reprogram it. It started only a few times before I got the no crank no start no security light situation going on.., talk about frustrating! My question is can I bypass the passlock 3 unit to get my car to start again.?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
When turning the ignition key to ON position, instrument panel lights and indicators all turn on for a few seconds then turn off with the oil, brake, battery and one or two more indicators remaining on until the engine is started. This is the power on self tests conducted every time ignition is turned on. Among the indicators is the factory Passlock security indicator, (yellow engine with large padlock?). This turns on then turns off under normal conditions. It may flash repeatedly or blink to indicate security conditions. Blink when armed after all doors are locked and security is enabled. Flashing indicates security detected a theft attempt, disables fuel and ignition to prevent starting but may not disable the starter; flashing indicator but allows the starter to crank the engine but without fuel and spark enabled, allows starter operation only without allowing the engine to fire up.
If you can see security cycle on and off before starting, Passlock is not active, disabling starting. A no crank, no start (zero starter noises) and security flashing may be an incorrect theft attempt detected and turned enabled Passlock security to disable fuel and spark circuits while flashing the security indicator. If this is what you see, leave ignition ON for 10 minutes until security resets and turns off the security indicator. Turn off ignition and try starting again. However, if security doesn't flash quickly while starting, this may be a dead, worn out battery and/or starter problem. A portable battery booster or another vehicle with jumper cables may be needed to provide a boost for starting.
I had a '03 GM Saturn with Passlock with service manuals. Manuals described factory security and each mode the security indicates from flashes or blinks. I think your '08 Malibu with Passlock 3 may have the same circuitry and flashing/blinking sequences.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
Yes the circuitry and sequences are identical in the that 03 Saturn and my 08 'bu. The problem I'm experiencing is no crank, no start WITHOUT any security light flashing whatsoever
- de Compartir
I'm on a fixed income and am not able to afford taking it into a mechanic to determine where the problem lies.
- de Compartir
Zero starter noises; faulty/dead battery, corroded battery cables and connections are the first things to examine. Engine off, battery voltage should be 12.5v. Try getting a boost from another car battery or portable boost pack.
- de Compartir
Añadir tu respuesta
Heidi Hemore estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 45
Todo El Tiempo: 176
