Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
La serie G de Infiniti es una línea de automóviles deportivos de lujo de nivel de entrada/ejecutivos compactos producidos por la división Infiniti de Nissan para los años modelo de 1991–1996 y 1999–presente.
No power to memory seat or side view mirrors or driver's side seat
what could be wrong
Update (07/01/26)
2007 Infiniti g35x sedan
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
3 comentarios
Hi @pain4200
What is the year of the vehicle?
- de Compartir
2007 Already replaced ADP, Seat switch, and checked all fuses.
- de Compartir
2007 G35x sedan
- de Compartir
Agregar un comentario
2 Respuestas
Respuesta Más Útil
@pain4200 if you are strictly referring to the memory function of the seats and mirrors then the common denominator would be the Automatic Drive Positioner (ADP) Control Unit. Use the AUTOMATIC DRIVE POSITIONER chapter from the SM for G35 sedan Adp to work (replace) on that.
Fue útil esta respuesta?
Puntuación 1
6 comentarios:
Already replaced ADP, seat switch to. The lumbar part still works and the steering wheel adjustment still works to.
- de Compartir
Neither of the 3 work at all
- de Compartir
The ecu had to be updated for the car to take the idle air volume relearn after throttle body replacements. Since then I have to put my key fob into the slot for the car to recognize it to push start it. would that have anything to do with it?
- de Compartir
@pain4200 sure looks like it. You seem to have issues with either the ECU or the BCM. This maybe one of those situations where you need the proper scanner to see if and what code you get and you may need to get those either reset or updated.
- de Compartir
@oldturkey03 Thanks, I'm leaning towards the BCM maybe having water damage or needs programming
- de Compartir
Mostrar 1 comentario más
Hi @pain4200
There doesn't seem to be anything in common between all these problem that I can see.
Below are the wiring diagrams for the areas that you listed.
Hopefully that may shed some light as to what the problem is.
side mirror
driver seat
Body Control Module
Puntuación 0
Añadir tu respuesta
Allen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 47
Todo El Tiempo: 190
