My phone screen is dropping out how to fix
How to stop from falling screen in f12
Es esta una buena pregunta?
@zaheed93866 could be an issue with the battery. If the battery is swelling up it will push the display out of the fram. This would mean you will have to replace the battery urgently. If it continues to swell it has the potential to cause more damage or worse, "vent with flame" which means it'll catch fire.
If the battery is okay and there is no other damage, then the issue could be that the adhesive from the screen has failed and you can try to re-apply some adhesive. It may also be necessary to replace the display if it has delaminated (the assembly itself is coming apart) For both of those cases follow LCD replacement instructions from something like this video
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 44
