Saltar al contenido principal
Aquí puedes consultar guías de reparación para MacBook.
Preguntas 3786 Ver todo
Broken display casing and hinges. How to swap with replacement parts
Hi all.
I dont fully know how to describe this. Basically my macbook fell of my bed and the screen half has broken off from the bottom, component/hardwear part off my mac.
The screen works and is hanging by a thread to the bottom half. I have to jostle it around untill it displays.
I have bought a faulty macbook with what i guess is a faulty logic board. the aesthetics/ casing are all perfect however
It switches on but doesnt recognise drive and doesnt charge.
To put it simply i have two 1/2 working macbooks.
Out of changing the power supply and logic board from the hardware working one, or transferring the screen half from one to the other.
Which is the easiet and is their a guide for it?
Thanks in advance people =)
much appreciated.
Es esta una buena pregunta?
Puntuación 0
3 comentarios
Please give us the last three figures of both serial numbers and we can get you to the correct guide.
- de
I dont havee serial for either as both top cases have been removed. And the spares repairs macbook came without a battery.
The screen damage macbook is late 2007 and the logic board failure is 2006
- de
Check if the two heatsinks have the same form factory. Also check if the inverter and fans connectors look the same.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Just swap the logic board from a machine to the other one if the two boards are compatibles.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
tom estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 460
