Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Cepillo de dientes recargable Oral-B Vitality de Proctor & Gamble con un temporizador de 2 minutos. Número de modelo D12513. Tipo de mango: 3709
Oral-B Vitality Type 3709 only works for few minutes
Hi. I have this weird issue with new old stock of this 3709 model where it would work for few minutes or maybe longer without brush head attached. When it nearly starts to act up, the toothbrush is behaving like the battery is nearly empty where the metal end vibrates very weak until it stops. When it stops, I could hear some sort of humming sound. I tried to move the metal end left and right, it seems like the motor inside is struggling to work. It feels like it's trying to move to vibrate, but it failed.
I let the toothbrush off for few minutes and after that, it starts working again at full speed like fully charged battery until few minutes of using it that the metal end gradually gets vibrate weaker and eventually stopped working again. Note that I didn't put it in the charger. I let it cool down for a while and the cycle repeats. Hopefully someone can help me. Thank you.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
There's two possibles here.
The first is the battery is failing as it's not able to sustain the needed power Sustitución de la batería Oral-B Vitality
The other is the motor bearing is seizing up as the shafts movement causes friction. Sadly that's the end of the unit as parts are not available.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
NextGeneration9501 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 20
Todo El Tiempo: 49
