Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La instalación eléctrica en los Estados Unidos se refiere al proceso de instalación de sistemas eléctricos en edificios y estructuras de conformidad con las regulaciones establecidas por el Código Eléctrico Nacional (NEC) y los códigos de construcción locales.
Why is the kitchen sink drain overflowing?
The kitchen sink does not drain used water out, instead it remains full in the since.
The vacuum switch to help suck out the water is not working.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
If your sink is below the sewer line elevation you need a holding tank which then is evacuated by a pump that emulates the needed lower elevation of the waste line.
Do you hear the pump motor running? If not the pump may have failed and/or it's not getting power. If you do hear the pump, but the water is still sitting in the basin the plumbing maybe clogged and/or the one-way valve to prevent back flow where dirty water can enter back into your sinks basin which you don't want.
You do need to be very careful as sewer water can carry some nasty bugs! Make sure you wash down the area with bleach as well as anything that could have been splashed and your sponges and cloths!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
DOROTHY GENDI estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 53
