Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
The first-generation XL-7 was Suzuki designed and had a body-on-frame construction. The North American version had a Suzuki-designed 2.5- or 2.7-liter V6 engine, on a rear-wheel drive-based platform with optional four-wheel drive. Beginning in 2003, European versions were also available with a 2.0-liter Peugeot turbodiesel engine producing 109 PS (80 kW).
Shift sensor light keeps coming on
Shift sensor light on dash continues to turn on how do I fix it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@rickyhadley that can happen for different reasons. It could be a shift solenoid issues, low or dirt transmission fluid or filter, as well as a faulty shifter. Start with the basic maintenance of checking the fluid, better yet changing it (and the filter). If that does not resolve it, the best would be to have your Suzuki's OBDII scanned and see what codes you get. That code will help to identify what the actual issues are.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Ricky Hadley estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 24
Todo El Tiempo: 64
