Why doesnt it start
I put a new oil filter, air filter, battery, spark plug, and head gasket. It wants to start and everything, but it just wont. It kind of seems like it needs a bit more force. If i cant fix it soon, i'm throwing it away. What should i do
Es esta una buena pregunta?
Puntuación
0
Juan Hernandez, you have to many things going on at one time with your mower. You replaced all those parts,, so have you checked the timing? Have you at least tried to see if it runs by either using a hand oiler and squirting a little bit of fuel either inside the carb, or inside the cylinder through the spark plug opening? Do you have spark at all? I suppose this is a one cylinder 4 cycle or 2 cycle engine? Does it have it have valves? Have you set your valve lash? When you remove the spark and crank the engine, do you have compression? There are lots of things that could be wrong, but the trouble shooting must be in some kind of order. Changing to many parts will confuse the issues. Check on the four things every combustion engine must have: Fuel, Air, Compression, and Spark.
- de oldturkey03
