Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Cruzer Blade es una unidad flash USB 2.0 lanzada por SanDisk.
The cruzer blade is rot read by my computer and pc
I inject the drive in the USB socket. It shows the USB drive is there but any files of the cruzer blade do not open.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
If your USB stick is detected then that is a good sign as indicates that it is a logical error. It could be file system corruption or minor drive errors which could be fixed.
First, check Disk Management (Win + X, then select Disk Management) to see if the drive has a letter assigned or if it shows as RAW. If there is no letter, assign one and try again.
Run an error check . Right click, select properties, go to the tools tab and click on check in the error checking section.
Imagen
If that doesn't work, would suggest that you take it to a professional service. there are data recovery software that you can use. If you do choose the DIY route, please do clone your USB stick before doing anything. You can use the Remo Free Disk Clone Tool for this.
However, I would still suggest that you take it to a professional if you have the means to.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Nimisha Gupta estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 85
