Saltar al contenido principal
Fecha de lanzamiento: 24 de enero de 2008; 8 MP, zoom óptico de 3x, sistema de estabilización de imagen óptica integrado y software de detección de rostros; Procesador de imagen DIGIC III.
Preguntas 13 Ver todo
water damage, won't turn on
Hi somebody,
My canon was dunked in water and after drying it out the camera makes no function...
how many fuses are and where they are?
Thaks,
Vidma
Es esta una buena pregunta?
Puntuación 0
6 comentarios
Have you disassembled and cleaned it yet?
- de
Hi oldturkey03, Thanks for the very fast and full-scale response!
I"ll try a bit later.
vidma
- de
the FUSE was not faulty,
I cleaned with alcohol, shorted the SWITCH on battery door, but still nothing.
Think stray current made more serious damages :(
- de
vidma, try to clean the logic board with with isopropyl camera. There are a few more fuses on the logic board. Check all those for continuity.
- de
Thanks oldturkey03, but how to find them, could you send me service manual with repair instruction and diagrams?
- de
Mostrar 1 comentario más
Agregar un comentario
1 Respuesta
Solución Elegida
vidma, the image will show you where the power fuse is located. Just remember that with water damage, a good cleaning with isopropyl alcohol is a must. Otherwise, you run the risk of corrosion failure later on. Here are more reason why your camera may not get any power:
"If electrical conduction is not found:
• FUSE is blown; replace it with a new one.
If the FUSE is not faulty:
• MAIN PCB Assembly excluding the FUSE is faulty
• OPERATION FPC Assembly is faulty
• TOP COVER UNIT is faulty
• BATTERY COVER is damaged.
• DETECT SWITCH(MAIN PCB assembly) is faulty"
Hope this helps, good luck
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Hi oldturkey03 I replaced the main then also cam is not getting on.where can I get all cam spares.plz help
- de
canon sd 1100 got dunked in juice , cleaned with ip also replace fuse 1001 then also not getting 8n plz help.
- de
Añadir tu respuesta
vidma estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 2,152
