Downward or forward vision sesnor error
My drone crash landed and its showing this error:downward vision sensor error
Es esta una buena pregunta?
"Since this error appeared after a crash landing, it could be either a calibration issue or physical damage. Here is the recommended workflow to fix it:
- Visual Inspection: Check the two small camera lenses at the bottom. Even a tiny scratch or dirt can cause this error. Clean them with a microfiber cloth.
- DJI Assistant 2 (Consumer Drones Series): This is the most common fix. Connect your drone to a PC/Mac and use the 'Calibration' tool. Follow the on-screen instructions to align the sensors using a patterned screen.
- Internal Check (If Calibration fails): If the calibration gets stuck at 0% or fails, the Flex Cable connecting the Vision Sensor to the Mainboard might be loose or damaged from the impact. You will need to open the shell and re-seat the connector.
- Hardware Replacement: If the above steps don't work, the Vision Sensor Module itself is likely cracked or dead and needs replacement."
If the software calibration fails, you need to proceed with a Hardware Inspection. Based on professional repair experience, follow these logical steps:
****** The DJI Mini 2 SE is built with very thin plastic and tiny connectors. Handle everything with extreme care. If you are not experienced in micro-repairs, you might cause more damage while opening the shell.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 27
Todo El Tiempo: 86
