Where is the fuse for the blower motor for a 2006 Dodge Ram 1500 it qu
Fuse for 2006 Dodge Ram 1500 Blower motor it quit blowing air
Es esta una buena pregunta?
@ronald71122 first you want to be trying all the fan speeds, if only a couple speeds work you need a "blower fan resistor" If none of the speed setting works, it could be a power issue or a bad blower motor or relay. Check fuse #4 in the integrated Power Module is located in the engine compartment near the battery (IPM). Turn the ignition ON and the blower switch on any speed. Now check for 12V+ power on the blower connector. Let us know what you find out.
To work on your heating system, use the 2004 Dodge Ram HVAC chapter. This is for an '04 but it will be identical to your '06
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 35
Todo El Tiempo: 267
