Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Wii Remote es el controlador principal original de la consola de juegos Nintendo Wii lanzada el 19 de noviembre de 2006. El número de modelo del Wii Remote original es RVL-003.
Normal functionality besides the Home, Minus, and Plus buttons
Hello, I recently acquired some old wiis and a corroded wii remote. I opened up the wii remote and did a complete clean of the entire board and battery terminals. Everything seems to be fine with the rest of the remote but the middle three buttons have no functionality. Any insight into a possible fix would be amazing.
Here is the board for reference
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi!
Yeah, most likely something on the motherboard and it won’t be an easy fix…
Not sure which component failed there… you can try replacing one button and see if that will do something, but I doubt it. The corrosion must have damaged something on the board.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Well I guess I'll just be grateful that it turns on it all and has part functionality, I separated the yellow membrane from the actual button and cleaned it as well but to no avail. I have no soldering skills so replacing a button is currently out of reach, but thank you for the suggestion.
- de
My pleasure! Then the only fix will be replacing the motherboard (which is basically the controller) or ask a repair shop! Sorry
- de
Añadir tu respuesta
Jacob H estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 96
