Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías de reparación, manuales y ayuda para la resolución de problemas de HP Victus 16. Accede a todo lo que necesitas para reparar tu HP Victus 16 tú mismo.
My laptop is not charging and turning on though my charging adapter ok
My laptop is not charging and not turning on
Though my laptop charging adapter is totally fine
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 8
3 comentarios
Having the same issue on my end. I was playing ‘Lies of P’ and my laptop randomly shut off on me. Now it’s not turning on nor is it charging. It’s also not turning on even when directly connected to the charger itself.
- de
@ck007 does it give you any sign of life? What have you already tried?
- de
I was show it for the technicians for maintenance , the IC of pc has been damaged
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
@sadmanrahman you are saying that "laptop charging adapter is totally fine" but are not telling us how you have checked that ;-) It's always important to give us all the details. We will also need to know what your computers exact model number is.
Assuming that your power adapter is working properly and that the connectors are not bend etc, you want to go ahead and check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Agregar imágenes a una pregunta existente
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
Fue útil esta respuesta?
Puntuación 2
its because your Mother board or power supply or battery is broken
Puntuación 0
Dekhate hi chage kam tha shutdown hua fir charge ni le rha hai chargar sahi hai
Puntuación 0
Añadir tu respuesta
Sadman Rahman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 71
Todo El Tiempo: 940
