Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Olympus OM-D E M10 Mark II es una cámara sin espejo de 16 megapíxeles que fue presentada en 2015. Esta cámara permite intercambiar objetivos gracias a su plataforma fácil de usar, la cual es sencilla y tiene un precio accesible para fotógrafos aficionados sin carecer de capacidades profesionales.
Warning about internal temp to high
Hi! I have this camera and as soon as I turn it on I get error that the internal temp is to high and it turns off. I have tried updating to latest firmware via SD-card and that worked. I also bought another battery to see if that helps. It seems that the internal temp sensor is broken or something. Is there a method to "reset" internal temp sensor? Has anyone disassembled the camera and know if it is hard to reach the sensor to look at? What would the next step be?
Oh, I also tried putting the camera in the freezer for maybe 30 mins but I instantly get the high temp warning even after that
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Well I doubt resetting will solve your issue, the alarm it trying to tell you there's a problem something is overheating! Did you get the camera wet or bang/drop it?
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
The camera looks to be in perfect condition and i don't think there had been water. The problem is i have tested to put it in the freezer for 30 min but it warns of heat instantly antway
- de
@patrikradacic - it's possible a sensor has failed. But it's not wise to put cameras into freezers! In the warmer chilled section yes but only when placed is a plastic bag with as much air removed! As you don't want condensation to collect inside!
- de
Añadir tu respuesta
Patrik Radacic estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 281
