Saltar al contenido principal
Información y guías de reparación para modelos de MacBook Pro con pantallas de 13".
Preguntas 9739 Ver todo
MacBook Pro will not boot properly
About two weeks ago a small amount of water was spilled on a friends macbook pro. It has been sitting since then and I decided to see if i can get it running.
When I press the power button (as one normally would when you start a computer) I can hear the HD try to spin for maybe a second or two, the front indicator light comes on, and then the computer shuts down immediately...BUT, when i hold the power button down for about 5 or so seconds, the hard drive will spin up and after the front indicator light blinks at me I can release the power button and it will boot as normal and run like a champ.
I am tech savvy but do not own a mac so please forgive if I don't use apple speak :)
FYI: its out of warranty
I have already performed the following tasks without any luck: reset NVRAM, installed new HD with ghosted image of original HD, taken the battery out to cycle power, tore the MBP completely down to the bones and cleaned the heat sinks and thermal paste (yes i applied new paste).
I am currently working on acquiring an OS disc (Snow Leopard) to try a clean install and see if that helps....
ANY IDEAS???
Cheers,
Wyz
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
4 Respuestas
Solución Elegida
Try resetting the SMC, here's how: http://support.apple.com/kb/HT3964
Fue útil esta respuesta?
Puntuación 2
1 comentario:
I tried resetting the SMC as suggested. Is there any way to know it has been reset? The light on the power supply never changed or cycled. Anyway, no luck, same situation. It seems very odd to me that if I hold the power button in it starts up...almost like i am overriding a setting or sensor. Also, I ran AHT and got the error: "4sns/1/40000000: IPOR - 9.166" Thanks for the help! Any other ideas?
- de
I have the same problem. But also cou will not clock higher than 800mhz. Not found a way of fixing it yet though!
Cpu would also use 100% unless in safe mode. But theres a file you can delete to stop kernel using all cpu.
Puntuación 0
I have this same issue as well. Not sure why this was marked answered if it didn't resolve the issue....
Puntuación 0
same problem here. solderd an brand new ic i625 still same issue
Puntuación 0
Añadir tu respuesta
Nick estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 2,597
