Saltar al contenido principal
Documentación de reparación para el mando DualSense de Sony PlayStation 5. Número de modelo: CFI-ZCT1W
Controller's board is flashing yellow 3 times when connected to power
Hello! Newbie here, I tried to replace the analog sticks on my PS5 controller as it had stick drift. After a long ride, I finally got the new modules installed and soldered to the board. I wanted to check if it still works and plugged the battery in. The LED on the front flashed 3 times in yellow color. There is another similar question here and, people are saying it is a short circuit. Is this board dead? Or can I do something to fix this issue?
Thank you!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hello Paul, did you put the controller fully back together when you tried to test to see if it still works? The 3 flashes in the yellow color can mean different things.
1st answer- 3 yellow/amber led flashes- The controller is going into rest mode it’s disconnected or the PS5 has entered sleep mode.
2nd answer- Controller can’t connect — could be low battery, no Bluetooth sync, or firmware crash.
could you provide me some more details please.
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
I didn't fully put it back together, just plugged the battery in the board and then connected it to my laptop via usb c to check the calibration tool. It is not showing up on my pc, it did show up prior to changing the analog modules.
- de
There's your problem!
• The battery provides power, so the microcontroller wakes up.
• It quickly performs a self-check.
• When it sees missing connections (like the USB board, touchpad ribbon, or trigger lines), it flashes yellow 3 times and shuts down to protect itself.
Go ahead and put it fully back together and then test it.
Get back to me if it works
- de
@carsons45505 Thank you! This didn't work for me, in the end I desoldered it and soldered everything again. Now it works like a charm, appreciate your help!
- de
Añadir tu respuesta
Paul Clodnischi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 30
Ultimos 30 días: 155
Todo El Tiempo: 282
