Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado el 23 de junio de 1996, modelo NUS-001, consola de juegos de 64 bits
Nintendo 64 PAL – No Signal After Reassembly
I have a PAL Nintendo 64 with the following issue.
When I first received the console, I disassembled and cleaned it. It worked fine.
Video quality was not great, so I replaced all electrolytic capacitors. The console still worked and I could play games.
After final reassembly in it's case, it started showing “No Signal.”
What I did so far:
Disassembled again, this time also removing heatsinks.
Cleaned everything again: card slot, AV cable, jumper pack contacts (even with 800-grit sandpaper).
Reflowed electrolytic capacitors and main chips: CPU, RCP, PIF, DENC, and jumper pack connector pins.
Tested various points with oscilloscope (I can share waveforms if needed).
Swapped my Expansion Pak with a new Jumper Pak.
Replaced power supply.
AV cable is brand new, so I don't think this is the cause.
Tried inserting/removing cartridge and jumper pack while powered on (as suggested in some threads).
At this point the console still gives no video output at all.
Any advice on what I should check next?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi!
It’s probably a broken capacitor.
I would replace them and see how that goes.
As it was working before, it’s probably positioned correctly on the motherboard. But please double check it.
Also, make sure that all the traces are still fine! Please also clean everything with isopropyl alcohol if not done earlier.
Please let us know how it goes!
Fue útil esta respuesta?
Puntuación 1
8 comentarios:
Thanks, I've already removed and reinstalled them (the new ones that I've installed at first recap)
I've done capacitance measurements, only one seem not correct but I'm doing the measures on board.
I can try remove them again and measure them of board. I dont have an esr meter, but they are panasonic brand new...
- de
My pleasure! I think that one of the new capacitors are having issues. The only way to be sure is to get them out and measure them… or replacing them again for new ones and see how that goes. Sorry..
- de
Desolered all electrolytics. Measured their capacitance and they seem all good to me
- de
@dan0 Also if I'm correct all ecaps, beside the ones filtering 3.3v 5v or 12v, are connected to the AMP-NUS or to the two audio outputs. Am I missing something?
- de
Nope, that is correct so far I know. Something on the motherboard did died... Could be a lot of things. Maybe it's easier to get a broken (donor) motherboard (like with no sound) and swap components with it. It's hard to say atm what is wrong... Sorry.
- de
Mostrar 3 comentarios más
Añadir tu respuesta
Ale estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 85
