Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Información de soporte y reparación para receptores AV de cine en casa y receptores de audio antiguos de Marantz.
My amplifier blow the right channel speaker
I have Marantz model 1072 amplifier. The left speaker plays sound on all the selector inputs. But the right speaker blow. I Measure a 33.5 volt on the right speaker output. What is causing it..
Es esta una buena pregunta?
Puntuación 0
2 comentarios
@francois61923 what do you measure on the left?
- de
On the left speaker i measure 0 voltage
- de
Agregar un comentario
2 Respuestas
Solución Elegida
33.5V on the speaker will definitely blow it. Circuits are different, but if there is an output cap on the line, it could be shorted. A direct connect push-pull circuit could have a shorted transistor, or the feed could be turning full on one side. Or if it is driven by a integrated amp, the amp is shorted out.
Fue útil esta respuesta?
Puntuación 0
Respuesta Más Útil
@francois61923 could be an overvoltage issues based on a bad power amp transistors. Time for you to look at your boards and see if you identify any "odd" looking component etc. Here is the Marantz 1072 1050 SM use that to check the schematics. If unsure, take some well focused pictures of your boards and post those with your Question. Who knows, we might just see something that might be helpful. Agregar imágenes a una pregunta existente
Puntuación 1
1 comentario:
Thank you, i look around on the board now to see anything od
- de
Añadir tu respuesta
Francois estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 278
