Cloned Startup External SSD only boots if Option held at power up
Latest Ventura 13.7.7
Cloned a very slow internal HDD to an external SSD using the Thunderbolt port and SuperDuper and The Migration Assistant. Boots fine. Cloning sucessful. (?) Then erased the internal thinking all was good. Result.
The infamous . (AaaaaaaaaaaH!)
Note it will still boot fine but only IF I hold down the Option key while pressing the Power button and select the (ONLY drive listed) the External SSD. Once at desktop I again selected the only listed drive the extermal SSD as the Startup drive.
And not from Restart from desktop.
Reboot or Shutdown results in the Question Mark screen. Hold down Option key at power on and boots fine.
Is there a simple solution?
I have tried NVRAM reset.
Terminal
"diskutil list" lists all the drives, etc but no mark as "Bootable" which I guess explains the need for Option key from power on.
"sudo bless --mount /Volumes/MyVolume Name --setBoot"
and got this error "Could not set boot device property: 0xe00002e2".
signed,
An IFIXITer seeing from the punters' side.
Es esta una buena pregunta?
