Need help identifying burnt components on Ninja Creami NC50X-PW board
Hello,
I’m repairing a Ninja Creami device (model NC50X-PW, revision V2.0) that was mistakenly connected to a 220V power source instead of 110V. Several components on the main PCB were damaged — one IC labeled U300 has a cracked case, and another labeled IC3 (likely a voltage regulator) is completely destroyed.
Unfortunately, I don’t have a schematic or BOM for this board. I’ve attached detailed photos of the board and the affected areas. If anyone has worked on this model or can help identify these components, I’d be very grateful.
Thank you in advance!
Es esta una buena pregunta?
Hi. I have the same problem. Just wanted to know if you were able to fix the Ninja Creami.
- de icpa
